Does the Teryx H2 have reverse lights?
Nikal
Does the H2 have reverse lights built into the tail lights? If it does you can splice in the Garmin Treadmill Bluetooth camera to the reverse lights wire for power & activation, and anytime you put the H2 in reverse it will automatically pop up on the Garmin screen just like your car or truck would. But you need a reverse trigger & power for it to work. The factory Kawi camera I’m told does not work this way and you have to toggle through your menu options to turn it on the dash display, and then do the same to turn it off.
So if anyone can confirm if it has reverse lights that would be great. If not I’ll find out this week at the Sand Sports Super Show at the OC fair grounds.
Reverse lights are part of most vehicle’s standard features, so it does. Apart from it being part of the lighting system, it can also be modified to suit your taste.
Confirmed it does not have reverse lights.
