AXE
- Joined
- Feb 9, 2026
- Messages
- 105
- Reaction score
- 71
Recently I started smelling fuel in the cabin of the H2 after driving just a short distance. No leaks detected. I've seen some recent posts about the same issue and it seems as though its a pinched vent line, plugged line or bad rollover check valve. Also rollover valve might not be installed correctly.
I ran mine a few miles with the gas cap loosely installed. This seemed to help, but maybe not 100% cause the gas cap vents into the cabin too.
So I decided to pull the seat and center console to check the line and valve. Had to remove the seat and console (see pictures). Line seemed fine no kinks and I pushed some short blips of air through it from the tank end of the hose and could hear it venting.
I haven't pulled the check valve yet, but noticed after another blip of air it did not seem to vent much. Maybe I caused the valve to stick or damaged it even though I was only using <20 psi of air. Anybody know what direction the valve should point (see picture)? I sort of feel like its the right direction, but might be faulty. Might get an aftermarket valve and see what happens.
