2026 Kawasaki Teryx 4 H2 Specifications
Dragoon
POWER
Engine:
4-stroke, DOHC, 4-valve, in-line 4-cylinder, liquid-cooled
Displacement: 999cc
Maximum Horsepower: 250.0 hp¹ @ 9,000 rpm
Maximum Torque: 146.3 lb-ft @ 8,800 rpm
Bore x Stroke: 73.4 x 59.0mm
Compression Ratio: 7.8:1
Fuel System: DFI® with (4) 40mm throttle bodies with dual injection; Kawasaki Supercharger
Ignition: TCBI with electronic advance
Starting System: Electric
Transmission: Automatic CVT with centrifugal clutch (H,L,N,R)
Final Drive: Selectable 2WD/4WD with locking front differential, shaft
Engine Braking: Yes
CAPABILITY
Front Suspension / Wheel Travel:
Double wishbone, FOX 3.0 Internal Bypass shocks, adjustable compression damping and adjustable preload/23.2 in
Rear Suspension / Wheel Travel: 4-link trailing-arm rear suspension, FOX 3.0 Internal Bypass Shocks, adjustable compression damping and adjustable preload/24.0 in
Front Tires: Maxxis® Carnivore Plus 33 x 10.00R16
Rear Tires: Maxxis® Carnivore Plus 33 x 10.00R16
Steering: Electric Power Steering (EPS) / rack-and-pinion
Front Brakes: 270mm dual hydraulic discs with 3-piston calipers
Rear Brakes: 270mm dual hydraulic discs with 2-piston calipers
Ground Clearance: 16.5 in (max) / 16.1 in (std)
Fuel Capacity: 14.8 gal
Turning Radius: 24.9 ft
Cargo Bed Dimensions (LxWxH): 14.6 x 33.1 x 9.1 in
Cargo Bed Load Capacity: 300 lb
Payload Capacity: 1,076 lb
Seating Capacity: 4-person (2 row), bucket seats with 4-point seatbelts
Lighting: All-LED lighting
DETAILS
Frame:
Ladder type, tubular steel
Overall Length: 159.4 in
Overall Width: 74.0 in
Overall Height: 71.5 in
Estimated Dry Weight: 2,291.0 lb** / 2,293.2 lb** CA Model
Curb Weight: 2,425.5 lb* / 2,427.7 lb* CA Model
Wheelbase: 126.0 in
Instruments: Digital speedometer, tachometer, fuel gauge, gear indicator (L, H, N, R), Driving Mode (2WD/4WD/4WD+Diff Lock), Power Mode (Full/Mid/Low), Economical Riding Indicator, connected indicator, clock, odometer, dual trip meters, total time, trip time, average speed, engine temperature, intake air temperature, battery voltage, boost pressure, CTV temperature, seatbelt warning lamp, maintenance reminder, oil warning lamp, engine check lamp, engine temperature warning lamp, neutral indicator, reverse indicator, headlight highbeam indicator, parking indicator lamp, battery warning lamp, EPS warning lamp, and CVT belt warning lamp
Additional Features: 7-in Full-color TFT Instrumentation with Smartphone Connectivity via RIDEOLOGY THE APP POWERSPORTS, Steel skid-plates w/ drain holes, ERGO-FIT®, 2 DC outlets, 2 USB ports, 8 cup holders, Additional storage
Color Choices: Lime Green
